Guest Operating System for VSM
peter2727
I was wondering which Guest Operating System people are using for their VSM when installing it on a VM (not using a Nexus 1010).
I know the attached picture are the server minimum requirements, but I would like to get a consensus of what most people are using.
Thanks!
Robert Burns
Peter,
When you deploy from the OVA or Installer App - the default option is "Other Linux 64-bit"
That's the preferred & only option you should ever be using.
Robert
