How to configure Nexus1000v for Hyper-v
licheng19891220
hi,
    I want to konw how to configure Nexus1000v for Hyper-v
     I can configure the basic configuration just like the uplink is access port, the port connect to VMs is also access port.
     But I can't configure the Uplink as Trunk mode . I don't know how to do it .
    I want to achieve this scense:  2 physical NIC make a  port-channel as Uplink and my vitrual machine are in different vlans.
    Any one can  provide some configure examples?
    Thanks.
lwatta
The configuration for Hyper-V is different then the way it works for ESX.
A lot of the configuration needs to happen within SCVMM and there are also some new concepts that get added to the VSM.
Have you looked at the install guides?
http://www.cisco.com/en/US/products/ps13056/prod_installation_guides_list.html
It's a good starting point. If you still need some help let me know and I might able to send you some additional info.
louis
lwatta
louis
