How to connect modem to Nexus 3048? should I use the RS-232 Serial console port
VinsonQu98255
Francesco Molino
What do you mean how to connect a modem? Are you talking about modem for internet connection? If yes, connect it using ethernet cable.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Thank you so much, Francesco.
I mean if I should use RS232 serial port to connect to a modem? I need to use a phone number to dail in as the out-of-band access to the switch.
Best Regards,
Vinson
