how to find if nexus switch is using ntpv1?
gavinhans
how to find if nexus switch is using ntpv1? or receiving ntpv1 packets?
Christopher Hart
Hi Gavin!
Based on my research, there does not appear to be any NTP CLI command that explicitly shows the version of NTP packets being sent to a peer or received from a peer.
However, one can use the Ethanalyzer control plane packet capture utility to capture NTP traffic matching a specific NTP version number. An example of this is shown below from my lab, where the switch owns an IP address of 192.0.2.10 and is configured to poll time via NTPv2 from 192.0.2.20 and 192.0.2.21.
RTP-HOM-VTEP-1# ethanalyzer local interface mgmt display-filter ntp.flags.vn==2 limit-captured-frames 0
Capturing on mgmt0
2020-09-07 12:48:10.018899 192.0.2.10 -> 192.0.2.20 NTP NTP client
2020-09-07 12:48:10.027238 192.0.2.20 -> 192.0.2.10 NTP NTP server
2020-09-07 12:48:12.018793 192.0.2.10 -> 192.0.2.20 NTP NTP client
2020-09-07 12:48:12.027296 192.0.2.20 -> 192.0.2.10 NTP NTP server
2020-09-07 12:48:14.018801 192.0.2.10 -> 192.0.2.20 NTP NTP client
2020-09-07 12:48:14.027228 192.0.2.20 -> 192.0.2.10 NTP NTP server
2020-09-07 12:48:16.018820 192.0.2.10 -> 192.0.2.20 NTP NTP client
2020-09-07 12:48:16.027353 192.0.2.20 -> 192.0.2.10 NTP NTP server
2020-09-07 12:48:25.018707 192.0.2.10 -> 192.0.2.21 NTP NTP client
2020-09-07 12:48:25.025964 192.0.2.21 -> 192.0.2.10 NTP NTP server
2020-09-07 12:48:27.018905 192.0.2.10 -> 192.0.2.21 NTP NTP client
2020-09-07 12:48:27.025959 192.0.2.21 -> 192.0.2.10 NTP NTP server
2020-09-07 12:48:29.018692 192.0.2.10 -> 192.0.2.21 NTP NTP client
2020-09-07 12:48:29.025933 192.0.2.21 -> 192.0.2.10 NTP NTP server
2020-09-07 12:48:31.018704 192.0.2.10 -> 192.0.2.21 NTP NTP client
2020-09-07 12:48:31.026100 192.0.2.21 -> 192.0.2.10 NTP NTP server
16 packets captured
Note that the above command will only capture NTPv2 traffic sent and received on the switch's mgmt0 interface. If you are polling time via NTP through an inband interface (such as a routed interface or an SVI), you will need to use the below command:
switch# ethanalyzer local interface inband display-filter ntp.flags.vn==2 limit-captured-frames 0
If you would like to see if the switch is receiving any NTPv1 traffic via inband interfaces, you can use the below command:
switch# ethanalyzer local interface inband display-filter ntp.flags.vn==1 limit-captured-frames 0
If you would like to see if the switch is receiving any NTPv1 traffic via the mgmt0 interface, you can use the below command:
switch# ethanalyzer local interface mgmt display-filter ntp.flags.vn==1 limit-captured-frames 0
I hope this helps - thank you!
-Christopher
