how to view MDS port channel details
nflnetwork
we have 4 physical fiber connections from a FI 6248 running to an MDS 9300
How can i check the details of this port-channel?
How can i see all members of this port-channel?
Can i see WWPN or only the physical interface (eg. fc1/1, fc1/2,fc1/3,fc1/4)
system: version 8.3(1)
thanks,
nflnetwork
i guess the FI ports that are members of this port-channel are technically not initiator ports so they don't show up in the flogi database of the MDS. Is that correct?
Sergiu.Daniluk
Hi @nflnetwork
I believe this is the command you are looking for
MDS#show interface port-channel 1
port-channel1 is up
    Hardware is Fibre Channel
    Port WWN is <WWPN>
    Admin port mode is F, trunk mode is off
    snmp link state traps are enabled
    Port mode is F
    Port vsan is 11
    Speed is 48 Gbps
    admin fec state is down
    oper fec state is down
    5 minutes input rate 189504 bits/sec,23688 bytes/sec, 17 frames/sec
    5 minutes output rate 8448 bits/sec,1056 bytes/sec, 6 frames/sec
      145584140731 frames input,276121297369656 bytes
        0 discards,11 errors
        5 invalid CRC/FCS,0 unknown class
        0 too long,0 too short
      528507290961 frames output,1058234252522244 bytes
        799 discards,0 errors
      102 input OLS,169  LRR,77 NOS,0 loop inits
      132 output OLS,73 LRR, 120 NOS, 0 loop inits
    Member[1] : fc1/1
    Member[2] : fc1/2
    Member[3] : fc1/3
    Member[4] : fc1/4
    Interface last changed at <>
Cheers,
Sergiu
