Intra VXLAN routing with Nexus 9K
DEV1389
Hello Team,
I want to implement routing between VXLAN by using multicasting on Cisco Nexus 9K . Can anyone share some configuration reference.
WAQ
Alex.M
Howdy,
If you haven't found a configuration reference guide yet for VxLAN, I would check this out.  This guide has many different versions that relate to NX-OS code versions.  If you know the NX-OS version you are wanting to run in your environment, I would recommend looking for the corresponding VxLAN configuration guide.
Hth,
Alex Molina
