09-03-2018 06:03 AM
hi out there
We encountered a problem where a portchannel to a IBM host suddenly died - the link is running as 2 link Portchannel ( ethernet 101/1/11 on nx1 and ethernet 102/1/11 on nx2)
These links are build as portchannel spanning the two nexus trough a vPC
nx #1
interface port-channel111
description SAP
switchport
switchport access vlan 2
vpc 111
vPC status
id Port Status Consistency Active VLANs
111 Po111 up success 2
interface Ethernet101/1/11
description SAP
switchport
channel-group 111 mode active
no shutdown
sh int po 111
port-channel111 is up
admin state is up
vPC Status: Up, vPC number: 111
Hardware: Port-Channel, address: 0041.d228.374c (bia 0041.d228.374c)
Description: SAP
MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec
Encapsulation ARPA, medium is broadcast
Port mode is access
full-duplex, 10 Gb/s
Input flow-control is off, output flow-control is on
Auto-mdix is turned off
Switchport monitor is off
EtherType is 0x8100
Members in this channel: Eth101/1/11
6 interface resets
Load-Interval #1: 30 seconds
30 seconds input rate 2216 bits/sec, 2 packets/sec
30 seconds output rate 2091560 bits/sec, 742 packets/sec
input rate 2.22 Kbps, 2 pps; output rate 2.09 Mbps, 742 pps
Load-Interval #2: 5 minute (300 seconds)
300 seconds input rate 2120 bits/sec, 2 packets/sec
300 seconds output rate 3123960 bits/sec, 793 packets/sec
input rate 2.12 Kbps, 2 pps; output rate 3.12 Mbps, 793 pps
RX
4282567481 unicast packets 690254 multicast packets 128062 broadcast packe
ts
4283385797 input packets 2388294822502 bytes
0 jumbo packets 0 storm suppression packets
0 runts 0 giants 0 CRC/FCS 0 no buffer
0 input error 0 short frame 0 overrun 0 underrun 0 ignored
0 watchdog 0 bad etype drop 0 bad proto drop 0 if down drop
0 input with dribble 0 input discard
0 Rx pause
TX
9456756464 unicast packets 76216532 multicast packets 6493734 broadcast pa
ckets
9539466730 output packets 4672927026231 bytes
0 jumbo packets
0 output error 0 collision 0 deferred 0 late collision
0 lost carrier 0 no carrier 0 babble 0 output discard
0 Tx pause
similar on the other nexus
here is the logging:
09-03-2018 11:49 PM
Was the port-channel up on the other side? Can you provide the output for the following command on both devices?
"show lacp internal event-history interface ethernet 101/1/11"
ADP
09-05-2018 02:35 AM
See if we take the first box here - DCDISTSW01:
09-05-2018 09:40 AM
09-09-2018 10:20 AM
hi nazimkha - I think we have found the root-cause - looks as some driver-problems with the server we are servicing here - as you can see in my next post it looks promising (but the vpc is nicely converged etc)
br ti
09-05-2018 01:29 PM
Are you sure you scrolled down to very bottom on DCDISTSW01?
The output should terminate with "Curr state" as you can see on DCDISTSW02 .
ADP
09-09-2018 10:19 AM
hi again
thanks for your suggestions and input - we might have found the root cause here because the server-team got some "fixes" for the ibm server - and now it looks much nicer - we have added a new poerchannel just to play safe and now is the last entry:
68) FSM:<Ethernet101/1/16> Transition at 428408 usecs after Sat Sep 8 00:46:45 2018
Previous state: [LACP_ST_PORT_MEMBER_RECEIVE_ENABLED]
Triggered event: [LACP_EV_PARTNER_PDU_IN_SYNC_COLLECT_ENABLED_DISTRIBUTING_DISABLED]
Next state: [LACP_ST_WAIT_FOR_HW_TO_PROGRAM_TRANSMIT_PATH]
69) FSM:<Ethernet101/1/16> Transition at 439049 usecs after Sat Sep 8 00:46:45 2018
Previous state: [LACP_ST_WAIT_FOR_HW_TO_PROGRAM_TRANSMIT_PATH]
Triggered event: [LACP_EV_PORT_HW_PATH_ENABLED]
Next state: [LACP_ST_PORT_MEMBER_COLLECTING_AND_DISTRIBUTING_ENABLED]
now is a single days uptime not an indication of stability - but the state here looks promising..
