n3k-c3172-tq-10gt os upgrade [Installation failed. Return code 0x40930014 (configuration copy failed)]
Jun123123
n3k-c3172-tq-10gt The operating system of the device was started for the first time.
Version: 7.0 (3) I2 (2b)
Version: nxos.7.0.3.I4.8b.bin
-First OS upgrade attempt-
Switch_3(config)# install all nxos bootflash:nxos.7.0.3.I4.8b.bin
Installer will perform compatibility check first. Please wait.
Installer is forced disruptive
Verifying image bootflash:/nxos.7.0.3.I4.8b.bin for boot variable "nxos".
[####################] 100% -- SUCCESS
Verifying image type.
[## ] 5% -- SUCCESS
Preparing "nxos" version info using image bootflash:/nxos.7.0.3.I4.8b.bin.
Preparing "bios" version info using image bootflash:/nxos.7.0.3.I4.8b.bin.
Collecting "running" plugin(s) information.
[# ] 0%
Collecting plugin(s) information from "new" image.
[# ] 0%
Performing runtime checks.
Performing module support checks.
Notifying services about system upgrade.
Compatibility check is done:
Module bootable Impact Install-type Reason
1 yes disruptive reset Incompatible image
Images will be upgraded according to following table:
Module Image Running-Version(pri:alt) New-Version Upg-Required
1 nxos 7.0(3)I2(2b) 7.0(3)I4(8b) yes
1 bios v3.5.0(01/25/2016) v4.0.0(12/05/2016) yes
Switch will be reloaded for disruptive upgrade.
Do you want to continue with the installation (y/n)? [n] ^C
Really abort ISSU? y/n [n]-
DATA_Server_Switch_3(config)# ye installation (y/n)? [n]
% Invalid parameter detected at '^' marker.
DATA_Server_Switch_3(config)# show boot
Current Boot Variables:
sup-1
NXOS variable = bootflash:/nxos.7.0.3.I2.2b.bin
No module boot variable set
Boot Variables on next reload:
sup-1
After installing the first OS, when asked whether to reload, I accidentally entered a typo and proceeded with OS Install again.
-Second OS Upgrade-
[# ] 0%
[# ] 0%
Do you want to continue with the installation (y/n)? [n] y
Install is in progress, please wait.
Setting boot variables.
Performing configuration copy.
[####################] 100% -- FAIL.
Return code 0x401E0000 (request was aborted).
Resetting boot variables. Please wait.
Install has failed. Return code 0x40930014 (Configuration copy failed).
Please identify the cause of the failure, and try 'install all' again.
DATA_Server_Switch_3(config)# Install has failed. Return code 0x40930014 (Configuration copy failed).
However, the command that the configuration copy failed has been issued, and the save to config is currently not possible.
After the second attempt, I forcefully reloaded the equipment, and all configs were lost and the equipment was initialized.
After resetting the backed up content, I tried to save it, but the log below appears, and the config is not saved.
2019 Jan 24:28:03 Switch_3 %SECURITYD-2-INVALID_ADMIN_PASSWD
2019 Jan 24:28:03 Switch_3 %SYSMGR-3-CFGWRITE_SRVFAILED: Service "Security Daemon" failed to store items configuration (error-id 0x404A0052).
2019 Jan 24:28:03 Switch_3 %SYSMGR-2-CFGWRITE_ABORTED: Configuration copy bound.
2019 Jan 24:28:04 Switch_3 %SYSMGR-3-CFGWRITE_FAILED: Configuration copy failed (error-id 0x401E0000).
I wonder if there are any mistakes I made during OS upgrade or if there is any way I can recover them.
Have you ever tried? Set password for admin account and save config, it would be failed?
9 Replies 9
Hanfeng Cai
It looks issue caused by fact that system did not have password defined for ADMIN username.
Please try following cmd:
username admin password #%^$#  <<<< set up a new password for admin account
The password for the admin account, the default account, is known to be empty,
I am wondering if it is appropriate to set it separately,
If you set the password for the admin account as you like, you can not save the current config,
I wonder if it will be a solution.
Thank you very much for your reply.
I have never tried it.
If you try,
switch (config): username admin privilege15 password (empty)
I wonder if you should try this way.
I know that the default id / pw of the nexus admin account is id: admin, pw: empty (enter).
never set it as empty, you must set an actual pw
I understand that I need to set the PW of the default account admin.
If so, I do not understand the message that comes out as an incompatible image in the OS version.
These messages appeared during the installation process as shown below.
I wonder what "collecting running" means below.
Does it mean to copy the current config to the upgraded OS image?
[# ] 0%
[# ] 0%
The following is a message after Yes to inquire whether to proceed with reboot after OS upgrade.
The OS of the device was installed by installing the recommended version nxos.7.0.3.I4.8b.bin. (https://software.cisco.com/download/home/285001670/type/282088129/release/7.0%25283%2529I4%25288b%2529?i=!pp)
Switch_3(config)#
Switch_3(config)#
% Invalid command at '^' marker.
Switch_3(config)# ^C
Switch_3(config)#
Switch_3(config)#
Switch_3(config)#
Switch_3(config)#
sup-1
NXOS variable = bootflash:/nxos.7.0.3.I4.8b.bin
sup-1
Switch_3(config)#
In the inventory information below, we are currently using the N3K-C3172TQ-10GT.
The OS of the device was downloaded from the recommended version nxos.7.0.3.i4.8b.bin. (https://software.cisco.com/download/home/285001670/type/282088129/release/7.0%25283%2529I4%25288b%2529?i=!pp)
Did I download the wrong OS and proceed with the installation?
The Prod. # Of the device is N3K-C3172TQ-32T, which can be found at (https://www.cisco.com/c/en/us/support/switches/nexus-3172tq-32t-switch/model.html) Product For the ID value,
The model N3K-C3172TQ-10GT is not specified.
NAME: "Chassis", DESCR: "Nexus 3172T Chassis"
PID: N3K-C3172TQ-10GT , VID: V01 ,
NAME: "Slot 1", DESCR: "48x10GT + 6x40G Supervisor"
I suppose this is a cosmetic issue, but I don't have lab to verify it. You could open a TAC case to look into it.
After upgrading to the recommended OS,
I can confirm that the new version has been uploaded,
I can not reboot and force a reboot,
All configurations have disappeared.
This event does not set the PW in the admin account after all, and the boot path is not saved and changed.
Could it be a problem booting to an existing version when rebooting?
Thank you for your reply.
I wonder what kind of problem is the appearance problem.
