nexus 3k with servers
Mohamed.Ashraf
Hello
Kindly find attached file.
I have 2 nexus 3k with vpc connected to servers.
When i configure the vpc under port-channel , i can't ping to server.
Appreciate your feedback.
Thank you
13 Replies 13
balaji.bandi
Can you explain more here? which port-channel is this ? and what physical port the Server connected?
what is the Server (windows ?)  side config ? is this LACP ? or Active-Standby?
BB
Hello B.B
Port-chanel 75
connected to Hyper-V
if you get chance to simulate the issue
can you post
show vpc
show port-channel summary interface port-channel 75
Also, try change from Active to ON (both the nexus and let us know)
channel-group mode on
BB
Hello B.B
Kindly fina attached file.
Hello B.B
The protocol at VMware LACP
I think i must make port-channel Active
Appreciate your help
I am confused here or am i reading wrong,
1. First, you mentioned Hyper-V
2. Second, you comment VMWARE? ( do you have vSwitch configured inside VMWARE, is this Exsi or VMWARE Workstation?
Can you explain how is your setup? Physically connected to where?
I have also requested below output from switch. ( i do believe,  you lost connection due that Port-channel not come up ?)
show vpc
BB
Hello B.B
First,i want to apologize for this case.
Second, the customer moving servers from Hyper-V to VMware.
Third , The Configuration as you want :
For Primary Switch :
B1DC-02A-Upper(config)# show vpc
Legend:
(*) - local vPC is down, forwarding via vPC peer-link
vPC domain id : 1
Peer status : peer adjacency formed ok
vPC keep-alive status : peer is alive
Configuration consistency status : success
Per-vlan consistency status : success
Type-2 consistency status : success
vPC role : primary
Number of vPCs configured : 3
Peer Gateway : Disabled
Dual-active excluded VLANs : -
Graceful Consistency Check : Enabled
Auto-recovery status : Enabled, timer is off.(timeout = 240s)
Delay-restore status : Timer is off.(timeout = 30s)
Delay-restore SVI status : Timer is off.(timeout = 10s)
vPC Peer-link status
id Port Status Active vlans
1 Po999 up 1,32,110,1100-1115
vPC status
id Port Status Consistency Reason Active vlans
70 Po70 up success success 1,32,110,11
00-1115
75 Po75 up success success 1100
888 Po888 down* success success -
B1DC-02A-Upper(config)# show vpc peer-keepalive
--Peer is alive for : (185156) seconds, (68) msec
--Send status : Success
--Last send at : 2020.01.12 12:23:51 696 ms
--Sent on interface : mgmt0
--Receive status : Success
--Last receive at : 2020.01.12 12:23:51 697 ms
--Received on interface : mgmt0
--Last update from peer : (0) seconds, (10) msec
vPC Keep-alive parameters
--Destination : 10.10.10.2
--Keepalive interval : 1000 msec
--Keepalive timeout : 5 seconds
--Keepalive hold timeout : 3 seconds
--Keepalive vrf : management
--Keepalive udp port : 3200
--Keepalive tos : 192
B1DC-02A-Upper(config)# show port-
port-channel port-profile
B1DC-02A-Upper(config)# show port-channel summary
Flags: D - Down P - Up in port-channel (members)
I - Individual H - Hot-standby (LACP only)
s - Suspended r - Module-removed
S - Switched R - Routed
U - Up (port-channel)
p - Up in delay-lacp mode (member)
M - Not in use. Min-links not met
Group Port- Type Protocol Member Ports
Channel
4 Po4(SD) Eth NONE --
13 Po13(SD) Eth NONE --
21 Po21(SD) Eth NONE --
22 Po22(SD) Eth NONE --
23 Po23(SU) Eth LACP Eth1/9(P) Eth1/10(s)
25 Po25(SD) Eth NONE --
26 Po26(SD) Eth NONE --
27 Po27(SD) Eth NONE --
30 Po30(SD) Eth NONE --
31 Po31(SD) Eth NONE --
40 Po40(SD) Eth NONE --
41 Po41(SD) Eth NONE --
46 Po46(SD) Eth LACP Eth1/22(D)
50 Po50(SD) Eth NONE --
52 Po52(SU) Eth LACP Eth1/11(P) Eth1/12(P)
60 Po60(SU) Eth LACP Eth1/16(P) Eth1/17(P)
61 Po61(SU) Eth LACP Eth1/18(P) Eth1/21(D)
70 Po70(SU) Eth NONE Eth1/13(P) Eth1/14(P)
71 Po71(SD) Eth NONE --
75 Po75(SU) Eth LACP Eth1/31(P) Eth1/32(P)
888 Po888(SD) Eth NONE Eth1/53/1(D)
999 Po999(SU) Eth LACP Eth1/49(P) Eth1/50(P)
For Secondary Switch :
B1DC-02B-LOWER(config)# show vpc
Legend:
vPC domain id : 1
vPC role : secondary
vPC status
00-1115
B1DC-02B-LOWER(config)# show vpc peer-keepalive
--Peer is alive for : (1693093) seconds, (645) msec
--Last send at : 2020.01.12 12:25:39 967 ms
--Last receive at : 2020.01.12 12:25:39 968 ms
--Last update from peer : (0) seconds, (6) msec
--Destination : 10.10.10.1
B1DC-02B-LOWER(config)# show port-
B1DC-02B-LOWER(config)# show port-channel summary
Channel
2 Po2(SD) Eth NONE --
3 Po3(SD) Eth NONE --
14 Po14(SD) Eth NONE --
23 Po23(SD) Eth NONE --
32 Po32(SD) Eth LACP Eth1/13(D) Eth1/14(D) Eth1/15(D)
Eth1/16(D)
45 Po45(SU) Eth LACP Eth1/29(P) Eth1/30(P)
46 Po46(SU) Eth LACP Eth1/31(P) Eth1/32(P)
52 Po52(SD) Eth NONE --
60 Po60(SD) Eth NONE --
61 Po61(SD) Eth NONE --
62 Po62(SU) Eth LACP Eth1/37(P) Eth1/38(P)
63 Po63(SU) Eth LACP Eth1/39(P) Eth1/41(D)
70 Po70(SU) Eth NONE Eth1/5(P) Eth1/6(P)
75 Po75(SU) Eth LACP Eth1/20(P) Eth1/21(P)
76 Po76(SD) Eth NONE --
754 Po754(SD) Eth NONE --
Thank you
Hello
On the server make sure your teaming is setup correctly that you have the Vnics in the correct vlan that is tagged
Kind Regards
Paul
Hello Paul
yes ,There are teaming on the server configured.
Hello
@Mohamed.Ashraf wrote:
Hello Paul
Are they in a tagged vlan such as 1100 ?
Kind Regards
Paul
Looks good to me as per Switch side, so when you enable vPC is the port-channel still up ?
Make sure you have correct setup on vSwitch side.
BB
Hello B.B
I want you to know , When i enable the VPC on port-channel i can't access the server althought when i remove VPC from port-channel that make me access the server.
HAve you checked on the Server connecting the Console and Monitor, what is the status on Esxi  side ?
Can you post you esxi vswitch screen shot to understand better on this issue. we do not see for now any issue on switch side.
BB
