Nexus 5600 - ERSPAN - Does not work - Cannot set default VRF in ERSPAN Destination
mindgame71
Dear all
Even the ERSPAN monitoring shows it is up it does not work with cisco Nexus 5672UP - version 7.0(8)N1(1). No traffic is send through.
Configuration is correct until the fact that in ERSPAN Destination the default VRF cannot be set (in ERSPAN Source default VRF can be set):
SWITCH-A(config-erspan-dst)#
 vrf ? *** No matching command found in current mode, matching in (config) mode *** context Create VRF and enter VRF mode
Does anybody set up ERSPAN with 2 NK5 (Software version?)? Does any body came into the same issue with the default VRF (just in ERSPAN Destination)?
Many thanks and best Regards
mojafri
Hi @mindgame71,
ERSPAN-dest is by default is for default vrf. You don't have to set it up. Moreover vrf command won't work.
Rate if you find it helpful.
MJ
Dear mojafri
Thanks for the information that ERSPAN-dest is by default in "default vrf". Anyway the monitoring is up but no traffic is not coming through.
Best Regards
