Nexus 6k NTP Troubleshooting
udo.konstantin
on a given network there are two Nexus 6001 with Version 7.3.8.N1.1which are the NTP Servers for other network devices. Also NTP authentication is active.
While working on the config I notice the following:
show ntp statistics local
....snip....
packets processed: 20912
bad authentication: 315153
...snip....
I want to find out which systems are not authenticating correctly. I tried with ethanalyzer on Nexus with a detail output. But I didn't found on the log file anything which leads to the bad authentication.
Any help?
Udo
anpetit
Hello @udo.konstantin ,
Checking your post, I don't know if you checked the following:
show ntp peer-status
show ntp authentication-status
Bad authentication could come from ACL as well as wrong authentication key configuration.
Let me know if it helps.
Kind Regards,
Antoine
