Does Nexus 93180YC-EX NX-OS support 100Mb port speeds?
Madura Malwatte
Level 4
Level 4
We recently have purchased Nexus 93180YC-EX switches and require to use 100Mb port speed with the GLC-TE transceivers. The data sheet doesn't mention this switch can support 100Mb port. However another cisco discussion indicates it may be supported? - https://community.cisco.com/t5/application-centric/nexus-93180yc-ex-100mb-on-aci-vs-nx-os/td-p/3819462
Can someone please confirm if I can use GLC-TE and set the port to 100Mb speed?
6 Replies 6
Sergiu.Daniluk
Hi @Madura Malwatte
Nexus 93180YC-EX does not support 100MB port speed. Reference: https://www.cisco.com/c/dam/en/us/products/switches/nexus-9000-series-switches/nexus-9300-10GE-fiber-switches-comparison.html
You can also confirm that by using command:
show interface eth x/y capabilities
Here are all Nexus 9300 models which supports 100M:
https://www.cisco.com/c/dam/en/us/products/switches/nexus-9000-series-switches/nexus-9300-10GbaseT-switches-comparison.html
Stay safe,
Sergiu
maybe it's not written in documentation, but look at the output of your provided command:
sh int e1/14 capabilities
Ethernet1/14
Model: N9K-C93180YC-EX
Type (SFP capable): 10Gbase-(unknown)
Speed: 100,1000,10000,25000
According this output, it should be possible, but I don't have it verified.
I found this:
 100mb optics, such as the GLC-TE, are supported in 100mb speed only on -EX and -FX switches, such as the N9K-C93180YC-EX and N9K-C93180YC-FX switches, and only on front panel ports 1/1-48. 100mb optics are not supported any other switches. 100mb optics cannot be used on EX or FX leaf switches on port profile converted downlink ports (1/49-52) using QSA.
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/aci/apic/sw/4-x/release-notes/Cisco-ACI-NX-OS-Release-Notes-1411.html
Hi @MV_SK
Then I stand corrected
If the capabilities command says it supports 100M, then it does.Indeed, I double checked it in my lab as well (should have done it before responding :)) and it lists 100M as well:
# show int e 1/1 capabilities
Ethernet1/1
  Model:                 N9K-C93180YC-FX
Thanks for bringing it up!
Cheers,
Sergiu
hi team, so the nexus N9K-C93180YC-FX supports speeds of 100Mbps, I have a client who is migrating equipment and has 4 ports at 100mbps, all the others are in Fiber SFP/SFP+, Does anyone in practice have it connected with GLC-TE transceivers and that support 100Mbps speed?
Carlos P.
Bel Marsad
Hi, we have the same issue with our  N9K-C93180YC-FX, we tried with GLC-TE and even with GLC-T supposed to be 10/100/1000. Inserting to the Nexus, we saw terminal log saying :
%ETHPORT-5-IF_HARDWARE: Interface Ethernet1/36, hardware type changed to 1G
But transceiver type showing 100Mbit/sec
Connecting 100MB device to this port, the port still down, even if you force speed to 100MB
Any advise ?
Best regards
Belmar
Bel Marsad
I found the solution.
- Remove the GLC-T from the interface
- Reset the interface to the default
- Reconfigure the interface with the access vlan and force the speed to 100 MB
- No shut and insert SFP GLC-T and connect your device
- Ping the device from your Nexus and its works for me
Best regards
