nexus 7710 switchover cause evms failure
mahdihabashi
hi everyone
I have nexus 7710 switch and it suddenly started a switchover cause by "evms failure". can you please tell me what is evms and how i can prevent this from happening?
nxos version : 8.4.2
sup 2E
nexus 7710
Can you share
Show cores
MHM
anpetit
Hello @mahdihabashi ,
Hope you are doing well.
EVMS failure usually require RMA of the faulty SUP.
Due to lack of logs, it's hard to correctrly troubleshoot the issue, the best would be to open a TAC case to have this troubleshooted.
Helpful logs will be:
show tech-support details
Check also the presence of a possible core file related to EVMS process:
show cores
VDC  Module  Instance  Process-name     PID       Date(Year-Month-Day Time)
1    5       1         evms             7558      2021-11-11 00:09:38
nexus# dir logflash:core
Hope it helps.
Kind Regards,
Antoine
