Nexus 9300 license question
mike-greene
Level 4
Level 4
Were going to be purchasing a couple N9K-C93360YC-FX2's to replace a couple 56128's.  On the new 9K's we'll only need layer2 functions and the ability to create multiple SVI's and a few static routes.  Do we need an additional license added to the 9K's for this like Data Center Networking Essentials?  Seems a little hard to understand all the Cisco licensing doc's to get an answer.
Thanks for your guidance.
Mike
ericnich
Mike,
You shouldn't need an additional license. If you end up on NX-OS 10.2(1) or newer, configure all of the features you plan to use and then execute this command:
license smart save usage all bootflash:rum.txt
You don't need a license if it returns "Failure: save status: The requested item was not found". Otherwise, follow this guide: https://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/nx-os/licensing/guide/cisco-nexus-nx-os-smart-licensing-using-policy-user-guide/m-configuring-slp.html
mike-greene
Level 4
Level 4
Thanks for the response...much appreciated.
Mike
