Nexus 93180YC-EX with FEX 2248TP
de1denta
Level 3
Level 3
Hi All,
I'm looking to connect a couple of 2248TP Fabric Extenders to a Nexus 93180YC-EX parent switch at 40GbE using QSFP to 4 x SFP+ direct-attached cables (QSFP-4SFP10G-CU1M)
Can someone please confirm if this is supported, and if so, how the Nexus 9K needs to be configured to convert a 40GbE interface into 4 x 10Gb SFP+ interfaces?
Thank you
2 Accepted Solutions
nazimkha
Level 4
Level 4
I have QSFP-4SFP10G-CU1M cables for this purpose, will they work ok?
Yes
Also do you know what config needs to be applied to the Nexus 9K switches to convert a QSPF interface into 4 x SFP+
You just need to breakout the interface and apply regular FEX config.
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/7-x/interfaces/configuration/guide/b_Cisco_Nexus_9000_Series_NX-OS_Interfaces_Configuration_Guide_7x/b_Cisco_Nexus_9000_Series_NX-OS_Interfaces_Configuration_Guide_7x_chapter_010....
Please note that I have not tested the config.
nazimkha
Level 4
Level 4
Yes it is supported. You need to use a breakout cable or SFP
https://www.cisco.com/c/dam/en/us/td/docs/switches/datacenter/nexus9000/hw/interoperability/fexmatrix/fextables.html
Some options
QSFP-4X10G-AOC, Cisco QSFP-40G-CSR4
https://www.cisco.com/c/en/us/products/collateral/interfaces-modules/transceiver-modules/data_sheet_c78-660083.html
Please mark the post resolved if it answers your query
Thanks for the prompt response.
Many thanks,
Yes
Command to split 40g QSFP into 4x10g:
interface breakout module <module #> port <port #> map 10g-4x
