Nexus 9332 Alternatives Commands for System nve Infra-Vlans VXLAN
mahdihabashi
Hi Everyone
I have a Nexus 9332 Switch and as you know it doesn't support Command System NVE infra-vlans .
I'm looking for an alternative for this command. can i just choose a random vlan and just allow it on Peer-link. then configure its SVIs on both switches and run an IGP Between them with a high cost. so just in case of uplink outage that path will be used !
Am i correct or is there any other solution for this problem guys ?!
Thanks !
f00z
Level 3
Level 3
Yes just select any vlan and use it for the IGP.
The infra-vlans is particular to the Tahoe ASIC only , the 9332pq/ 9372 is Trident2 BCM ASIC.. Tahoe is EX/FX/etc.   I assume you are referring to the 9332pq and not the 9332c.
f00z
Level 3
Level 3
