Nexus 9932PQ - Breakout configuration
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
11-08-2018 06:36 AM
Hi Team,
i got a question regarding the (re-) configuration of the breakout module on Nexus 9932PQ.
In the environment are running two Nexus 9932PQ as a core switch. The two devices are connected via 2x40Gig.
First of all we have (big) maintenance window, so there is now time pressure while doing this. Interfaces 1-8 are configured as Breakoutports with the command "interface breakout module 1 port 1-8 map 10g-4x".
We need one those interfaces as a native 40G interface, which basically means we need to convert one port, for example, port 8 back to 40G.
Now my question:
Can i simply to this by entering: "no interface breakout module 1 port 8 map 10g-4x" or is it necessary to remove the configuration of the complete module with by entering " "no interface breakout module 1 port 1-8 map 10g-4x"
I know that i need to power off and power on the module (and copy run start) after removing the config of the breakout-ports.
Thanks in advance!
Andreas
- Labels:
Nexus Series Switches
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-08-2018 07:58 AM - edited 11-08-2018 07:58 AM
Hi @AndiBuchmann157,
Command "no interface breakout module 1 port 8 map 10g-4x" will work perfectly fine. You don't have to remove the whole breakout config. It will only affect port-8, moreover in runn-conf you will see "8" getting removed.
Something like this in below eg.:
N9K-C9332PQ-1(config)# sh run | sec break interface breakout module 1 port 6,8-12 map 10g-4x N9K-C9332PQ-1(config)# no interface breakout module 1 port 9 map 10g-4x N9K-C9332PQ-1(config)# sh run | sec break interface breakout module 1 port 6,8,10-12 map 10g-4x
Please rate if you find it helpful.
MJ
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-08-2018 08:09 AM
Thank you!
So after entered the command i gave in my first post / you mentioned i still will see later:
Eth1/1/1-4
Eth1/2/1-4
Eth1/3/1-4
Eth1/7/1-4
and starting then Eth1/8, Eth1/9, Eth1/10 and so on, right?
--> Which means my Eth1/8 will just work as a native 40G Interface beginning from this point.
Another question:
Why exactly are the most right six ports (Eth1/27 - 32) of the 9332PQ marked yellow? I checked the following output (Eth1/26):
Core-xyz# show int eth1/26 capabilities
Ethernet1/26
Model: N9K-C9332PQ
Type (SFP capable): unknown
Speed: 40000
Duplex: full
Trunk encap. type: 802.1Q
Channel: yes
Broadcast suppression: percentage(0-100)
Flowcontrol: rx-(off/on),tx-(off/on)
Rate mode: dedicated
Port mode: Routed,Switched
QOS scheduling: rx-(none),tx-(4q)
CoS rewrite: yes
ToS rewrite: yes
SPAN: yes
UDLD: yes
MDIX: no
TDR capable: no
Link Debounce: yes
Link Debounce Time: yes
FEX Fabric: yes
dot1Q-tunnel mode: yes
Pvlan Trunk capable: yes
Port Group Members: none
EEE (efficient-eth): no
PFC capable: yes
Buffer Boost capable: yes
Speed group capable: yes
Breakout capable: yes
compared to Eth1/27 (marked yellow):
Core-xyz# show int eth1/27 capabilities Ethernet1/27 Model: N9K-C9332PQ Type (SFP capable): QSFP-H40G-ACU10M Speed: 10000,40000 Duplex: full Trunk encap. type: 802.1Q Channel: yes Broadcast suppression: percentage(0-100) Flowcontrol: rx-(off/on),tx-(off/on) Rate mode: dedicated Port mode: Routed,Switched QOS scheduling: rx-(none),tx-(4q) CoS rewrite: yes ToS rewrite: yes SPAN: yes UDLD: yes MDIX: no TDR capable: no Link Debounce: yes Link Debounce Time: yes FEX Fabric: no dot1Q-tunnel mode: yes Pvlan Trunk capable: yes Port Group Members: 105-128 EEE (efficient-eth): no PFC capable: yes Buffer Boost capable: no Speed group capable: yes Breakout capable: no
From the output above i see that those ports are not capable of connecting a FEX or Breakoutcables - what are the other major differences i need to know right there?
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-08-2018 09:19 AM
Yes
--> Why exactly are the most right six ports (Eth1/27 - 32) of the 9332PQ marked yellow?
Those are called uplink port- does vxlan routing. Also called ALE port- more can be found here: https://www.cisco.com/c/en/us/products/collateral/switches/nexus-9000-series-switches/white-paper-c11-732452.html
--> From the output above i see that those ports are not capable of connecting a FEX or Breakoutcables - what are the other major differences i need to know right there?
Don't forget to mark answers as correct if it solves your problem. This helps others find the correct answer if they search for the same problem
MJ
