Nexus 9k Guestshell error: Account or password is expired, reset your password and try again
drussell
After performing a "yum update" on the guestshell of a Nexus 9300 (9.2.(3)) I get prompted for a password when I try to do a chvrf.  It doesn't take the switches password for admin.
[admin@guestshell ~]$ sudo chvrf management
sudo: Account or password is expired, reset your password and try again
Changing password for root.
(current) UNIX password:
Does anyone know how to get around this?
David,
Either workaround will suffice. The main issue is the "password must be changed" state of the root user prior to any workarounds, see below:
[admin@guestshell ~]$ sudo su -
[root@guestshell ~]# chage -l root
Last password change                                    : password must be changed
Password expires                                        : password must be changed
Password inactive                                       : password must be changed
Account expires                                         : never
Minimum number of days between password change          : 0
Maximum number of days between password change          : 99999
Number of days of warning before password expires       : 7
By changing the PW of the root user, you are effectively toggling it to "never" expire which is what we are interested in:
[root@guestshell ~]# passwd
New password:
Retype new password:
passwd: all authentication tokens updated successfully.
Now:
Last password change                                    : Apr 01, 2019
Password expires                                        : never
Password inactive                                       : never
Both workarounds accomplish the same: They set the root PW to never expire so you should be in the clear!
Other workaround here:
[root@guestshell ~]# chage --lastday -1 root
Last password change                                    : never
Glad to help.
- Andrea, CCIE #56739 R&S
Andrea Testino
Hi there,
Unfortunately, looks like you are running into CSCvo29238 (should be external in the next 24-48 hours). The issue is indeed triggered after a "yum update" has been executed within the guest shell.
The workaround is to use the following command such that the root password does not expire:
Hope that helps.
Thanks for the reply.
I found that if I create a password (in the guestshell) for the admin account right after I create the guestshell, then I don't have any issues after the yum update.
Are there any downsides with this approach?  Would I still need to run the command you suggested on the root account?
David
David,
New password:
Now:
Glad to help.
Thanks!
- David,  CCIE #5751 R&S
