Nexus 9k manual failover
aok
Hello
I have just noticed that our "active/standby" N9K pair does not have supervisor modules installed:
VCR1C1R4CS2# show module
Mod Ports Module-Type Model Status
1 48 1/10G SFP+ Ethernet Module N9K-C9396PX active *
2 12 40G Ethernet Expansion Module N9K-M12PQ ok
Mod Sw Hw Slot
1 7.0(3)I2(3) 1.0 NA
2 NA 1.3 GEM
Mod MAC-Address(es) Serial-Num
1 x-x-x-x-x-x-x-x xxx
2 x-x-x-x-x-x-x-xxxx
Mod Online Diag Status
1 Pass
2 Pass
* this terminal session
____
I was hoping to manually fail over the traffic from the active switch to the standby but it doesn't seem possible:
VCR1C1R4CS2# show system redundancy status
Redundancy mode
administrative: HA
operational: None
This supervisor (sup-1)
Redundancy state: Active, SC not present
Supervisor state: Active
Internal state: Active with no standby
Other supervisor (sup-1)
Redundancy state: Not present
___
There is a vpc peer-keepalive interface which is up and the two devices are able to see each other:
VCR1C1R4CS2# show vpc peer-keepalive
vPC keep-alive status : peer is alive
--Peer is alive for : (55957378) seconds, (952) msec
--Send status : Success
--Last send at : 2018.09.04 22:23:08 191 ms
--Sent on interface : mgmt0
--Receive status : Success
--Last receive at : 2018.09.04 22:23:08 191 ms
--Received on interface : mgmt0
--Last update from peer : (0) seconds, (532) msec
vPC Keep-alive parameters
--Destination : 172.19.10.48
--Keepalive interval : 1000 msec
--Keepalive timeout : 5 seconds
--Keepalive hold timeout : 3 seconds
--Keepalive vrf : management
--Keepalive udp port : 3200
--Keepalive tos : 192
____
Am I missing something? How do I fail over traffic from one N9K to the other?
AO
nazimkha
Level 4
Level 4
The Nexus N9K-C9396PX are fixed series of switches. The Nexus 9500 are the modular switches with redundant supervisor capability.
Based on the information you have provided it looks like you have 2 Nexus N9K-C9396PX in vPC. The vPC switches are not active / standby but active/active.
In vPC, to reboot one switch and ensure the network is not impacted depends on how your network is setup i.e servers and other devices dual homed to both the Nexus switches and there are also some other consideration in regards to vPC itself.
I would suggest to schedule a maintenance window and plan the activity
nazimkha
Level 4
Level 4
