Nexus 9K Syslog Server
Ivan Rivai
Hi all.
I have searched related documents regarding syslog server in nexus 9k and cant find anything about port customization in syslog. Does nexus 9k support custom port for syslog server? because i dont want to use default port 514.
Thank you.
Ivan
5 Replies 5
Ben Walters
Level 4
Level 4
You should be able to set the port within the logging server command by adding port <port #> to the command.
something like: logging server 192.168.25.55 0 port 55514 use-vrf default for example.
Hi Ben,
thank you for your reply.
When i type port , it showed invalid command. Maybe need to activate a feature?
Ben Walters
Level 4
Level 4
I don't believe it is feature related, but if you want to compare ours has the following features:
feature-set fex
feature private-vlan
feature interface-vlan
feature hsrp
feature lacp
feature vpc
feature lldp
We are also running NXOS 7.0(3)i4(2)
Hmm it's a bit weird. I can't run this cli : logging server 192.168.25.55 0 port 55514 use-vrf default
My hardware is Cisco Nexus9000 C9372PX chassis.
I'm currently running version 7.0(3)I1(2).
Where does it error out ?
Can you do a ' show run all | i server'
