Nexus9000: Is there a command to fix the ifIndex value?
YEH
Catalyst switches have a command to fix the ifIndex used in SNMP monitoring.
Switch(config)# snmp-server ifindex persist
Switch(config-if)# snmp-server ifindex persist
However, there does not seem to be a command for the Nexus switch.
Am I correct in assuming that on Nexus, the ifIndex is not changed by rebooting the device, etc.?
If there is a command to fix it, I would appreciate it if you could let me know.
Dawei
You are right, Nexus doesn't need this command, "ifIndex" is persist, you can verify it by below command:
show interface snmp-ifindex
Dawei
