06-15-2022 04:53 PM
Are passive 100G twin ax cables supported in N9K-C93180VC-FX3 and C9500-48Y4C-A switches?
Solved! Go to Solution.
06-15-2022 10:23 PM
Here are all the transceivers supported by:
You will find there all the 100G DAC cables supported by both switches.
Take care,
Sergiu
06-15-2022 10:23 PM
Take care,
Sergiu
06-16-2022 09:21 AM
Thanks!!
