port-channel
kdaramola
I have port channel created on a vss upstream switches with 2 ports bundled together  and I have port_profile created on 1000v  with channel group configured on port profile but won't come up.
sample config
port-profile type ethernet vm-traffic-uplink
  vmware port-group
  switchport mode access
  switchport access vlan 130
  channel-group auto mode passive
  no shutdown
  system vlan 120
  state enabled
Robert Burns
Why do you have access vlan 130 but "system vlan 120"? Also can you try mode active?
lwatta
Your port-profile config needs to mirror how the port-channel on the VSS is configured. So if it's a trunk on the VSS then it needs to be a trunk on the Nexus1000V. If its an access port on the VSS than make it an access port on the port-profile as well with the same vlan numbers.
Also what version of Nexus 1000V are you using? If you are using 1.4 I would recommend turning on LACP offload.
louis
ike1
This is a sample of the configs of the configs on a por-tcahnnel  config going to 2 NICcards on a server
interface Gigabit Etherneth 7/10
description server
switchport
swichport access vlan 10
no logging event link-status
load-interval 30
speed 1000
no snmp trap link-status
channel-group 20 mode on
