how to change vem packet vlan
irek.romaniuk
VEM packet vlan for some reason is   vlan 1
# vemcmd show card
Card control VLAN: 10
Card packet VLAN: 1
VSM is set to use vlan 12 as packet vlan , how do I change now ?
rsn1-1c-n1k# sh port-profile virtual usage
Port Profile               Port        Adapter        Owner
control                    Veth1       Net Adapter 1  RSN1-1C-Nexus1000V
                           Veth5       Net Adapter 1  RSN1-1C-NexusSecondary
packet                     Veth2       Net Adapter 3  RSN1-1C-Nexus1000V
                           Veth7       Net Adapter 3  RSN1-1C-NexusSecondary
rsn1-1c-n1k# sh port-profile name packet | inc vlan
  switchport access vlan 12
system vlans: 12
Thank you, but from svs domain context I can change to packet vlan 1 , and I want to change VEM to match svs settings not the other way arround
Irek,
You don't set the packet VLAN anywhere else than on the VSM.  As long as the VEMs are communicating with the VSM (showing as inserted) any change to the SVS domain properties will be propagated to all VEM hosts.
Robert
This is correct it was only under ['svs domain', I've not noticed it was setup with vlan 1. Changed to vlan 10, and now
'vemcmd show card' shows also vlan 10 Thank you for help
