Same Endpoint Learning From Multiple Path and Source
OBD
 I have an issue about learning sources in ACI fabric. When I run " show endpoint ip 192.168.5.20" , I see that endpoint is shown in different nodes and different ports by different sources (vmm and learned)  .  But when I run same command in leaf switches  the vmm sourced endpoints not shown. Only "learned" source endpoint shown as output.
 So does ACI not consider vmm sourced endpoints ?  I'm little confused about vmm sourced and learned source endpoint learning.
APIC01# show endpoints ip 192.168.5.20
IP Address Source Node Interface Encap
192.168.5.20 vmm 201 eth1/25 vlan-2704(P) vlan-2705(S)
192.168.5.20 vmm 201 eth1/32 vlan-2704(P) vlan-2705(S)
192.168.5.20 vmm 202 eth1/14 vlan-2704(P) vlan-2705(S)
192.168.5.20 vmm 202 eth1/12 vlan-2704(P) vlan-2705(S)
192.168.5.20 learned 202 eth1/8 vlan-2704(P) vlan-2705(S)
192.168.5.20 vmm 205 eth1/3 vlan-2704(P) vlan-2705(S)
192.168.5.20 vmm 206 eth1/4 vlan-2704(P) vlan-2705(S)
192.168.5.20 vmm 211 eth1/5 vlan-2704(P) vlan-2705(S)
LF202# show endpoint ip 192.168.5.20
VLAN/ Encap MAC Address MAC Info/ Interface
Domain VLAN IP Address IP Info
79 vlan-2705 0050.56b1.2646 L eth1/8
test:test vlan-2705 192.168.5.20 L eth1/8
LF206# show endpoint ip 192.168.5.20
test:test  192.168.5.20  tunnel48 --> Tunnel to the LF202
0 Replies 0
