sflow not sending data
Hi all,
I have configured sflow but the collector is not seeing any data
Here is my config am I missing something?
-NEXUS-CORE1#
-NEXUS-CORE1# show sflow
sflow sampling-rate : 50000
sflow max-sampled-size : 200
sflow counter-poll-interval : 100
sflow max-datagram-size : 2000
sflow collector-ip : 10.1.0.170 , vrf : default
sflow collector-port : 2055
sflow agent-ip : 10.0.253.253
-NEXUS-CORE1#
-NEXUS-CORE1# show sflow statistics
Total Packets : 0
Total Samples : 0
Processed Samples : 0
Dropped Samples : 0
Sent Datagrams : 5200
Dropped Datagrams : 91245
Anyone?
sp2720401
It might be a routing issue.
vrf default... that is the global VRF
If you are sourcing the SFLOW from the mgmtX interface the VRF should be set to "management"
VRF source is important. The destination needs to be reachable from that source VRF.
have you verified with any type of packet capture between the source and destination... are sflow packets leaving the source switch?
