SFP-H10GB-CU1M
Bob Greer
Level 4
Level 4
Hi there,
Thanks for reading.
Might be the wrong forum... we're connecting Catalyst 3850s to servers with SFP-H10GB-CU1M (2 ports each on two 3850s).  On both switches, one port is fine, the other is showing the hardware as "Te2/0/13" "1000BaseSX SFP" PID: GLC-SX-MMD"
Have you seen this before?  I tried speed nonegotiate but no difference.
Thanks again!
Bob
nazimkha
Level 4
Level 4
which version are you using ?
You should be on higher than IOS XE 3.7.2 or IOS 16.2.1
