09-01-2009 05:24 AM
There is a command "show tcp statistics" to get tcp statistics.
whether this tcp statistics are of VSM or it includes tcp statistics of VSM+VMs on ESX.
D V
09-01-2009 03:42 PM
These are the TCP statistics of the VSM only and does not include the stats for the VEM or VMs on the ESX
-- Ashwin
09-02-2009 04:39 AM
How can I get TCP statistics for VMs on VEM?
Should I use Netflow or ERSPAN? or
Is there any other way to get the same?
D V
09-02-2009 07:18 AM
Following configuration can be used to get tcp statistics for VMs:
flow record protocol-stats
match ip protocol
collect counter bytes
collect counter packets
flow exporter exp
destination <collector-ip>
flow monitor protocol-stats
exporter exp
By using above config you should be able to collect protocol-wise stats for all the interfaces on a VM. You can put following config in a port profile or directly on the interface which you want to monitor:
ip flow monitor protocol-stats input
ip flow monitor protocol-stats output
This would monitor traffic in both egress and ingress with respect to VM.
-Shachi
05-11-2024 12:55 PM
08-05-2024 04:38 AM - edited 08-05-2024 04:39 AM
These statistics help in diagnosing issues like congestion, connection drops, or suboptimal configurations, enabling targeted interventions to enhance network efficiency.
