Slow performance over VXLAN SVI, Nexus
als95
Hello!
I have a pretty standard XVLAN setup.  In that setup server "A" with IP 10.0.0.100/24 can successfully reach server "B" with IP 10.0.0.200/24. Iperf3 performance if very good - line rate.
My goal is to  have additional IPs on those servers, server "A" assigned IP 203.0.113.1/32 and server "B" assigned IP 203.0.113.2/32
[ srvA 203.0.113.1/32-lo + 10.0.0.100/24-eth0 ] <-> |vxlan-anycast gw 10.0.0.254/24| <-> [srvB 10.0.0.200/24-eth0 + 203.0.113.2/32-lo]
Those /32 IP are BGP propagated
Server's have only `default` route via anycast gateway 10.0.0.254
Output from the Nexus C9336C-FX2 switch. (Both 10.0.0.100 and 10.0.0.200 are on the same switch)
# show bgp vrf myvrf999 ipv4 unicast neighbor 10.0.0.100 routes
*>e203.0.113.1/32 10.0.0.100 0 65000 i
# show bgp vrf myvrf999 ipv4 unicast neighbor 10.0.0.200 routes
*>e203.0.113.2/32 10.0.0.200 0 65000 i
There is a reach-ability between those IPs:
root@serverA:~# tracepath -n 203.0.113.2
1?: [LOCALHOST] pmtu 1500
1: 10.0.0.254 0.682ms
1: 10.0.0.254 0.558ms
2:  203.0.113.2 0.409ms reached
Resume: pmtu 1500 hops 2 back 1
However iperf3 performance is very poor for those IPs
serverA:~# iperf3 -c 203.0.113.2 -p 5001 --bind 203.0.113.1
Connecting to host 203.0.113.2, port 5001
[ 5] local 203.0.113.1 port 38739 connected to 203.0.113.2 port 5001
[ ID] Interval Transfer Bitrate Retr Cwnd
[ 5] 0.00-1.00 sec 294 KBytes 2.41 Mbits/sec 5 4.24 KBytes
[ 5] 1.00-2.00 sec 0.00 Bytes 0.00 bits/sec 13 11.3 KBytes
[ 5] 2.00-3.00 sec 0.00 Bytes 0.00 bits/sec 1 15.6 KBytes
[ 5] 3.00-4.00 sec 0.00 Bytes 0.00 bits/sec 20 9.90 KBytes
[ 5] 4.00-5.00 sec 0.00 Bytes 0.00 bits/sec 4 7.07 KBytes
^C[ 5] 5.00-5.39 sec 0.00 Bytes 0.00 bits/sec 0 7.07 KBytes
Same test with the 10.0.0.x/24 IPs shows great throughput
root@serverA:~# iperf3 -c 10.0.0.200 -p 5001 --bind 10.0.0.100
Connecting to host 10.0.0.200, port 5001
[ 5] local 10.0.0.100 port 42939 connected to 10.0.0.200 port 5001
[ 5] 0.00-1.00 sec 3.03 GBytes 26.0 Gbits/sec 0 1.84 MBytes
[ 5] 1.00-2.00 sec 2.58 GBytes 22.2 Gbits/sec 0 1.84 MBytes
[ 5] 2.00-3.00 sec 2.33 GBytes 20.0 Gbits/sec 0 3.02 MBytes
^C[ 5] 3.00-3.69 sec 1.57 GBytes 19.5 Gbits/sec 0 3.02 MBytes
What could be the issue there?
als95
Yes, culprit was a re-use of the VNI in the fabric for the unrelated VLAN.
Dawei
Do you have enabled "no ip redirect" under your gw SVI? The most likely reason is that for some reason the switch doesn't hardware forwarding these packets.
als95
Looks like the issue may be related to re-use of the VNI in the fabric. I'm going to fix that and re-check.
als95
