Some vlan stp do not exist
wfqk
Level 5
Level 5
Hi Vlan 900 exists in the switch4500 and it is native. it shows "Spanning tree instance(s) for vlan 900 does not exist" when using command "show spanning-tree vlan 900. Why is that?
by command show run | b spanning, we can see "spanning-tree vlan 1-1000 priority 24570"
Thank you
Varun Jose
hello
can you paste below command outputs from the switch in question;
- show interface trunk
- show run
- show ip int b | in up
nazimkha
Does VLAN 900 exists in vlan database.
show vlan cli should show the vlan
