Cisco Nexus Module failed
raikone14
Some ports of my nexus sport to work, I checked the log and collected this messages:
2018 Aug 8 11:43:11 swa.001 %PLATFORM-2-MOD_REMOVE: Module 2 removed (Serial number JAE18160R11)
2018 Aug 8 11:43:13 swa.001 %PLATFORM-2-MOD_DETECT: Module 2 detected (Serial number JAE18160R11) Module-Type 1/10 Gbps Ethernet Module Model N77-F348XP-23
2018 Aug 8 11:43:13 swa.001 %PLATFORM-2-MOD_PWRUP: Module 2 powered up (Serial number JAE18160R11)
2018 Aug 8 11:43:13 swa.001 %PLATFORM-5-MOD_STATUS: Module 2 current-status is MOD_STATUS_POWERED_UP
2018 Aug 8 11:43:34 swa.001 %PLATFORM-2-MOD_PWRFAIL: Module 2 failed to power up (Serial number JAE19160R11)
2018 Aug 8 11:43:35 swa.001 %PLATFORM-2-MOD_REMOVE: Module 2 removed (Serial number JAE181R6011)
2018 Aug 8 11:43:37 swa.001 %PLATFORM-5-MOD_STATUS: Module 2 current-status is MOD_STATUS_ERRDOWN
2018 Aug 8 11:43:37 swa.001 %PLATFORM-3-MOD_PWRFAIL_MULTI: Module 2 failed to power up multiple times (Serial number JAE18160R11)
Wes Austin
Looks like a hardware related failure. I would open a TAC case for further diagnosis.
I moved all cables to another module.
But now I am having problems with my VPCS:
%ETH_PORT_CHANNEL-3-COMPAT_CHECK_FAILURE: Module Type Incompatible is not compatible
What can be  Incompatible type module ? his number ?
What platform? It's possible because you have vPC member ports on different line cards this is triggering the vPC consistency failure.
Are you able to provide the following out?
show vpc consistency-p int port-channel X <<----- where X is one of the vPC's
Jason L.
Are you trying to do a vPC between 2 different line cards ?
