Stackwise virtual config is not allowed on provisioned switch/line
Mr PSIT
Hi All,
I have 2 new C9500-24Y4C switches with ver 17.09.04 and network advantage licencing. I followed the seemingly straight forward commands to setup the stackwise virtual but I am getting the above error when I run the command "Stackwise-virtual link 1 " on my chosen interface. This is happening only on my second switch. I am not sure if i did something wrong that has caused this. Any ideas would be much appreciated.
Stackwise virtual config is not allowed on provisioned switch/line cards.
Mr PSIT
I got this sorted by resetting both switches using "write erase" and "no stackwise-virtual". I then reloaded and started again and all worked well. Happy Days!!  When I finished the stackwise-virtual config, I reloaded my first switch completely (let it reboot fully) before reloading the second switch.
7 Replies 7
marce1000
 - Checkout this thread : https://community.cisco.com/t5/switching/cataylst-9500-40x-vss-distributed-stack-config-is-not-allowed-on/td-p/4141408
 M.
Mr PSIT
Thanks M. I did see this post. When I do a "Show Switch" on both switches it just shows Switch 1 active. There is no second switch there. That error  also starts with "Distributed Stack config is not allowed " where my error states "Stackwise virtual config is not allowed"
Mr PSIT
Mr PSIT
Hi All,
Hello Mr PSIT. You posted this in the section for Data Center Switches, i.e., Nexus devices. I recommend moving it to the Catalyst section as they will be more informed on your question.
Thanks - I have moved it to the Catalyst section
Merged this duplicate thread with the one above and moving entire thread to Switching not Catalyst Center.
