04-21-2021 01:05 AM
HI Guys,
I have a switch Nexus 3064PQ stuck at bios.
(c) Copyright 2011, Cisco Systems.
N3000 BIOS v.1.7.0, Mon 10/14M
Unable to boot past this.
Anyone has already idea what's wrong with this?
Thanks in advance!
04-21-2021 01:17 AM
What actions did you performed before the problem appeared (upgrade, config etc)?
Sergiu
04-21-2021 02:34 AM
It is a refurbished set. Im not sure what did the previous supplier has done to it too.
Thanks!
04-21-2021 02:50 AM
Hi @whitegrape
If the device is not booting, then probably the device is bricked. There are some unsupported upgrades which can brick your switch (example: CSCva97678). You should return the switch and ask for a replacement.
Stay safe,
Sergiu
04-21-2021 09:36 PM
Hi Sergiu,
Thanks for your advise! Seems like the device is bricked.
I will look for other way!
Thanks for your help!
Roy
04-21-2021 02:28 AM
Connect the console post, power off and power on the device post complete output, may be you need to do recovery.
04-21-2021 02:36 AM
Thanks! actually I connect to the console port and it couldn't get past the bios. Im unable to load to the loader.
Im thinking any solution to find out the bios problem.
04-21-2021 02:53 AM
Raise an TAC case for RMA. If you have smartnet contract.
04-21-2021 09:36 PM
Hi BB,
I will try to solve on my side.
Roy
