Upgrade Nexus 9K nxos and bios
babalao
I need to upgrade a nexus 93130YC-FX from 10.2.5 to 10.4.4M wich is the recommended release.
But I also need to upgrade the BIOS from 5.47 to 5.51. Is there a specific command (and file/image) to upgrade the BIOS or when I do the upgrade if the NX-OS with "install all" command will also upgrade the BIOS.
Please advice.
Thank you in advance.
Regards.
Dawei
No, there is no need to upgrade the BIOS separately. You can refer the doc below:
The install all command is the recommended method for software upgrades and downgrades because it performs configuration compatibility checks and BIOS upgrades automatically.
https://www.cisco.com/c/en/us/td/docs/dcn/nx-os/nexus9000/104x/upgrade/cisco-nexus-9000-series-nx-os-software-upgrade-and-downgrade-guide-104x/m-upgrading-or-downgrading-the-cisco-nexus-9000-series-nx-os-software.html
