Users on the 1000v
Cy Hauptmann
Hi all,
Is there a limitation on 1.4.1 version of 1000v .... I've created a user with a role of network-admin but it doesn't have any of the Admin permission, ie cant run sho mod, can modify the any of the svs configs ...... is there something that I am missing??
Cy.
abbharga
Level 4
Level 4
Hi Cy,
Does the new user ID you created have more then 8 character in the login ID?
We did recently found this bug on the 1.4 version where the user ID with more then 8 characters have an issue executing the commands even with the network-admin rights.
Again if above is true can you also try a user-id with less 8 or less characters?
./Abhinav
