What is the preferred method for configuring management SVI on vPC pair
neilo
I have 2 x 9k switches, connected by vPC.  I have setup vPC and this is working fine, as per below:
Keepalive link is via the mgmt0 interface (192.168.200.10 & 20)
Peer-link is a portchannel using 2 x 40Gig links on each switch.
I can confirm this primary vPC environment seems to be working fine.
I have connected this vPC pair to my 6509 Core switch and the portchannel seems to be working fine.
What I now need to do is configure the vPC pair so I can remotely manage each of them on my network management subnet...what is the preferred method for configuring an SVI so I can access each switch via SSH?
My topology and config is attached.
Cheers
Neil
6 Replies 6
Sergiu.Daniluk
 Hello @neilo,
The best way to manage the Nexus switches is through mgmt0 interface connected to OOB network. This is because the mgmt0 interface has direct connection to CPU, and you are not going through COPP (Control Plane Policing). This is important during network loops or broadcast storms or some inband disruption, when a lot of traffic is being forwarded to Nexus' CPU, and CoPP starts dropping packets to protect the CPU.
If you directly connected the mgmt interface between the two N9K, no worries, you can move them to an OOB switch without impacting the vPC functionality. If only the VPC KA goes down, no changes happens to vpc peers state as long as vpc peer-link is up.
Let me know if you have any questions.
Best regards,
Sergiu
Hi Sergiu,
Many thanks for your response.  At this stage I'm not able to utilise an OOB network...I guess I'm trying to understand how vPC controls the switches and I'm guessing it doesn't truly act in the same way VSS does.  What is the next best preferred method, do I just configure an SVI on each Nexus and how will vPC manage that...will it not care because vPC is L2?
Neil
Hi @neilo,
I am a bit lazy with the drawing, but I found this:
Reference: https://www.dclessons.com/vpc-and-l3-design-scenarios
So from L3 perspective, the two vPC peers will act as individual routers. However, there is one small, but important difference.
When you configure an vPC SVI with HSRP, both vPC peers will actively forward the routed traffic. With 'vpc peer-gateway' the Nexus can even forward traffic is destined to it's peer.
Second important thing you need to know is what happens during vPC failure scenarios. More exactly, when peer-link goes down - on vPC operational secondary, the vPC SVIs and VPC port-channels will be suspended.
Which means, you should not configure the inband mgmt SVI as a vPC VLAN. What is a VPC vlan? It's a vlan not allowed over peer-link. Thus, make sure you have dedicated ports for inband mgmt VLAN, otherwise, you will not be able to manage your switches during a failure.
Cheers,
Sergiu
Thank you Sergiu, I appreciate your help...I've managed to get things working.  I've applied HSRP to my production management VLAN SVI on each switch and it's working as needed.
Thanks again
Neil
Hello
It looks like you using the MGT port for you peer-keepalive link which is a recommended best practice, I am aware of the 7K having a additional OOB port (CMP) which can be used however not sure its supported on the 9K's, The next best thing would be to create a mgt svi on each physical box append a hrsp/vrrp vip address to it and have that in it own vrf.
On a side note just been looking at your configuration and wondering if do you have an active peer-keepalive link?
interface mgmt0
vrf member management
ip address 192.168.100.10/2
vpc domain 10
peer-keepalive destination 192.168.100.20 source 192.168.100.10 vrf management <--- this is missing
Kind Regards
Paul
Hi Paul,
Thank you for your message, I have tried to follow the recommended best practise where I can as it's my first time using vPC.  I've no added HSRP to my SVIs and all is working fine.
My peer keep-a-live is up, the command has been applied but for some reason it doesn't show on the show run output.
Many thanks
Neil
