09-23-2019 10:04 PM
Hello Everyone,
we need upgrade nexus3548,and we don't want to interrupt service. I didn't find some documents for disscussion about ISSU.
So i want to comfirm whether Nexus3584 support zero interrupt upgrade or ISSU ?
Please give me the documents or upgrade guide if it support. Thanks
09-26-2019 03:54 PM
Hi SYGY,
What version of NX-OS the switch currently is running and to which version you want to upgrade?
You can check the releases notes of the version that you want to upgrade for the procedure.
In this tool you can check is ISSU is supported:
09-26-2019 08:21 PM
10-01-2019 03:21 PM
Hello SYGY,
Hope you are doing well. After reviewing the discussion, I can see that you are running code: 6.0(2)A7(2) on your Nexus 3548.
Unfortunately upgrading from this code, as described in the article below:
ISSU or Zero Interruption Upgrade is not supported and "Install All is the only option that supports upgrade and downgrade between releases."
Therefore, upgrading your code will indeed require a reload of the switch.
10-01-2019 07:58 PM
