work around for the bug CSCuc2460?
nagasheshu.2014
I am trying to configure flexible netflow in WS-C3850-48T running with 03.02.03.SE verison.
Obviously it is not working & after looking at release notes I found below bug details which is understandable which is why netflow is not working.
workaround provided was to create netflow out of VRF which is not possible in our case, Is there any other work around?
  • CSCuc24608
When the NetFlow collector address for the Flow Exporter is configured in the VRF route table, flow records are exported to the same IP address in the global route table.
The workaround is to connect the NetFlow collector in the global route table instead of the VRF route table.
Nagasheshu.
nagasheshu.2014
can someone please help?
Is it possible for you to upgrade to 3.3 and verify if this bug is an issue or your configuration.
Also you can try pasting your netflow configuration here
