TK0521
Community Member
Status: New
This is my first time connecting to the lab with CiscoAnyConnect. I was fine to establish the VPN in first time and then connected to the devices. However, due to my laptop was hang, I did the hard reboot. After the reboot, I failed to connect to VPN. The error messages were as attached.
Screenshot 2020-02-18 at 7.18.56 PM.pngScreenshot 2020-02-18 at 7.18.45 PM.png
I managed to connect back to the lab by end the lab and then did a new reserve. It seems the problem was due to my previous VPN connection was still active and the vpn system did not allow me to establish another new connection. May I have solution on this instead of re-do the reservation for same lab? Thanks.
1 Comment
Antonio123
Visitor
Hi, I have the same problem (you are not alone). I try multiple times to login per VPN in different Sandboxes. I always got the same error (see logs) I used AnyConnect on WIN7, WIN10 and openconnect on Linux (CentOS7), aways go the same error 'No assigned address' Here the logs: 2/20/2020 6:43:14 AM Contacting devnetsandbox-emea-gwy.cisco.com:20206. 6:43:27 AM User credentials entered. 6:43:28 AM Establishing VPN session... 6:43:28 AM The AnyConnect Downloader is performing update checks... 6:43:28 AM Checking for profile updates... 6:43:28 AM Checking for product updates... 6:43:28 AM Checking for customization updates... 6:43:28 AM Performing any required updates... 6:43:28 AM The AnyConnect Downloader updates have been completed. 6:43:28 AM Establishing VPN session... 6:43:28 AM Establishing VPN - Initiating connection... 6:43:28 AM Disconnect in progress, please wait... 6:43:29 AM The secure gateway has rejected the connection attempt. A new connection attempt to the same or another secure gateway is needed, which requires re-authentication. The following message was received from the secure gateway: No assigned address 6:43:29 AM AnyConnect was not able to establish a connection to the specified secure gateway. Please try connecting again. 6:43:29 AM Ready to connect.
