Edge Computing Infrastructure
Labels
HI , I have an IR829 GW Device, I would like to deploy an application that requires rf metrics as input . Im aware that IoS commands provide the RF metrics through show comamnds. Is there a way to access the rf metrics thIR829, IOx on IR829rough an a...
abi_Cheetah by • Frequent Visitor
  • 2086 Views
  • 2 replies
I tried to run a simple nginx default server on IR510 but I can't start it.ioxclient version 1.12.1.0 (On my Ubuntu 20.04 development machine)Here the stepsOK. Create the Dockerfile FROM arm32v7/nginx EXPOSE 80# Commands and test:# docker build -t ir...
rod.leon by • Visitor
  • 2600 Views
  • 1 replies
Hi, Expert      After upgrading my CAT 9300 IOS image from 16.6.6 to 16.12.4, all my old error messages have disappeared. But the installation of the IOx docker app still had problem. This time, it is this one. zbmvsw9300-01#app-hosting install appid...
Hi, Expert.       After I used ioxclient to build the package.tar file, I was installing it on Cisco 9300 switch. But I ran into a problem complaining schema version 2.8 is not supported. I used scheme version 2.8 and IoX version 16.6.6. Does anyone ...
I tried to pull a base image with this instruction. But I always ran into following problem. Anyone knows what is the problem? szhang-410-030:~/docker_test> sudo docker pull devhub-docker.cisco.com/iox-docker/ir800/base-rootfsFATA[0000] Invalid repos...
