Alert connectivity issue between ESA and SMA
Densha Otoko
I need detail method on how to detect if the ESA and SMA are unable to connect?
Can this be detected by an email from IronPort C600V Alert <alert@ces.cisco.com>
Thank you
balaji.bandi
Assuming you're on CES, Cisco's operations team will get and respond to alerts about ESA/SMA not communicating.
The alert configuration mentioned elsewhere only applies if you're managing your ESA/SMAs (vms or hardware deployed to infrastructure you control)
