IR1101 Dual WAN Setup with failover
owen2
HI,
For dual WAN Setup do I need to get the expansion module IRM-1100-SPMI or the router is able to support dual WAN configuration ?
Mirko Grabel
Hi Owen2,
The base model has one SFP/RJ45 combo port, 4 FE LAN interfaces and one slot for LTE.
You can use these interfaces at the same time for dual WAN.
But you are restricted to the interfaces available, examples:
- LTE + SFP/RJ45 (routed interface) works
- SFP/RJ45 + FE LAN (using SVI) works
- Dual LTE or Dual SFP / Routed port does NOT work.
To use dual LTE uplink or to use two routed interface uplinks you need the  IRM-1100-SPMI expansion module.
I hope this helps!
Mirko Grabel
Hi Owen2,
I hope this helps!
