0x80D1 - Invalid call reference value
axiansamiens
Hi all,
I can't receive any fax on only one DID. I have one 2901 on MGCP with e1
In my case this DID is for a FAX, there is my debug isdn q931 when I try to send a FAX
*Dec  4 21:46:39.214: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x6532
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Calling Party Number i = 0x2183, '955XXXXXX'
                Plan:ISDN, Type:National
        Called Party Number i = 0xA1, '3894'
        Sending Complete
*Dec  4 21:46:39.226: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0xE532
*Dec  4 21:46:39.226: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8  callref = 0xE532
        Progress Ind i = 0x8088 - In-band info or appropriate now available
And after 3 minutes trying i have this end:
*Dec  4 21:49:39.278: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x6532
        Cause i = 0x80E6333031 - Recovery on timer expiry
*Dec  4 21:49:39.310: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x6532
*Dec  4 21:49:39.330: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0xE532
*Dec  4 21:49:39.338: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x6532
        Cause i = 0x80D1 - Invalid call reference value
This fax is on gawteway VG224 but i have others FAX and it's works properly.
Somebody know this issue?
Thanks.
George Thomas
Level 10
Level 10
debug isdn q931 will not give that kind of detail, debug voip ccapi inout will atleast be required amongst other to identify the issue. When you say other FAX, is it on the same VG224? Are you able to fax internally between machiines? Are you using T38 or passthrough?
Please rate useful posts.
