1760 router doesn't connect to SIP server
Hello. I have a basic configuration and I noticed the router is not connecting to the SIP server. Inside the network I can sent/received calls without a problem. The router is connected to a linksys E3200, which is connected to a 2Wire gateway. I opened the firewall to make sure ports are ready. I noticed that some times when the command show sip register status is set to yes, but most of the time is set to no.
On my config I havent set up the outgoing dial peers. Thanks
VOICE#show sip register status
Line                              peer        expires(sec)  registered
333                               40001           33           no
5616236333                        -1          131           no
Can you please take a look and let me know where to look to find the reason this is happening.
Sounds like a NAT problem. Your 1760 sends SIP REGISTER with private IP address:
Sent:
REGISTER sip:sipconnect.ipcomms.net:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.13.20:5060;branch=z9hG4bK010F1
From: <>5616236333@sipconnect.ipcomms.net>;tag=C2DD-268C
To: <>5616236333@sipconnect.ipcomms.net>
Date: Thu, 02 May 2013 13:08:40 GMT
Call-ID: 32440D27-2BDE11D6-8002F8E3-B354FD0A
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1367500120
CSeq: 2 REGISTER
Contact: <5616236333>192.168.13.20:5060>
Expires:  3600
Content-Length: 0
These messages do not have any response.
Try to enable SIP ALG on your Linksys E3200:
Regards.
