Showing results forĀ
Search instead forĀ
Did you mean:Ā
1921 and VoIP support
lee.roberts
Could someone please confirm if the Cisco 1921 supports VoIP?
From what i can tell the Cisco 1921 router does not support VoIP, even with a VWIC3 card installed.
This diagram (from  http://www.cisco.com/c/en/us/products/collateral/routers/2800-series-integrated-services-routers-isr/data_sheet_c36-609138.html ) can be so misleading
If Voice is not supported, which would be the recommended Cisco router model to go for, 2911 maybe?
Thanks.
Jaime Valencia
It certainly doesn't show as supported for CME
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/requirements/guide/33matrix.html
java
if this helps, please rate
Jaime Valencia
java
Please note even though the 2900-series would be a good option for you, they have been announced EoL about a month ago: http://www.cisco.com/c/en/us/products/collateral/routers/2900-series-integrated-services-routers-isr/eos-eol-notice-c51-737831.html
The 4300-series will probably be your best option.
Thanks guys, much appreciated.
Also, its the festive season apparently, so lets leave these computer type thingys alone for a bit and go have some fun.
