IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5861 Views
  • 14 replies
UCS C240 10.68.1.15 -> CUCM1/CUCM2/Unity1/CCX1UCS C240 10.68.1.16 -> CUCM3/Unity2/CCX2Publisher    -> CUCM1Subscriber 1 -> CUCM2Subscriber 2 -> CUCM3firmware Upgrade done on 10.98.1.16 Now we need to upgrade the Firmware for UCS 10.98.1.15 Cisco Unif...
Hi All, my PSTN provider will upgrade their T1 line to SIP recently, and i have some concern about the VG configuration: Currents CUCM 11--------> H323------> Voice Gateway 3925 ---> T1 ------>PSTN In new scenario i got one SIP router from servic...
Kosi227 by Level 1
  • 238 Views
  • 1 replies
Hi, Need help on Cisco phones power up. This is for my Home Lab.  I have purchased Cisco 3550 Switch and 4 Cisco 7940 phones, when i try connecting the phones to switch, nothing happens (Blank Screen). On the Switch side, i see a behavior where the...
Hi all, I am using CUCM 11.0 and cisco 8851 .  when I try to change softkey ,it works(everything but digit after first ) . The customer asked me to change digit after first  layout  they want abbreviated dial first/seconed . When I apply this  noth...
Hi Dear,I have a question about  CUBE, How can I load sharing with per call on CUBE For example I have two dial  peer different session target I want to route to one calls different ISP one call  another ISP... (First call call should be route ISP ...
KY_ by Level 4
  • 1154 Views
  • 5 replies
Hi, I have the following DID  Gateway -G2 DID 2222000 2222499 Gateway -G1 did23320002332100 if the extension 1001 trying to call outside 9.2444200 and G2 fails called party should see  '2332000' how can i do that Thanks
Resolved! Call redirect
Hi , I have one issue I wanted to  direct the 858 xxx xxxx (receptionist when customer chooses 0 for operator) to the hunt group 888 xxx xxxx? how can I do that ?
S Sadiq by Level 1
  • 462 Views
  • 6 replies
