04-18-2013 10:28 AM - edited 03-16-2019 04:53 PM
We are running Call Manager 9.x and I have a 2921 with a VWIC2 1MFT module. We will have a 7 channel PRI coming into this card. The provider will present them as 2 different channel groups. One will be 1-6 and the other will be 7. The purpose is to support 2 different company names on this circuit. Channel 1-6 will have a different calling name from Channel 7.
Can this be done in CCM so that I can create 2 different route groups, one that is associated with Channels 1-6 and the other is associated with Channel 7?
I've tried creating trunk groups under the PRI, but in CCM when I create a route group, it only allows me to choose ALL ports on the MFT as opposed to the different trunk groups or specific ports.
We are using MGCP by the way.
Thanks in advance for any advice.
04-18-2013 01:15 PM
Not MGCP, you need H323 for that.
No way to do such with MGCP
Then just configure the dial-peers as required and use a prefix to choose over which channels you want to send the call
IE
111.XXXXXXXX
222.XXXXXXXX
And keep the same in the dial-peers, so you can choose one or the other based on the prefix, then just drop it before sending the call out to the PSTN.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
04-18-2013 01:23 PM
Ok, I was afraid you were going to say that. Ok, I'll test in the next day or so, and see if I can get that going.
Thanks.
05-20-2013 03:45 PM
Ok, I have this working now. Here's my config:
network-clock-participate wic 1
isdn switch-type primary-ni
trunk group 1stTrunkGroup
trunk group 2ndTrunkGroup
controller T1 0/1/0
pri-group timeslots 1-7,24
trunk-group 1stTrunkGroup timeslots 1-6
trunk-group 2ndTrunkGroup timeslots 7
interface Serial0/1/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn supp-service name calling
no cdp enable
voice-port 0/1/0:23
dial-peer voice 5000 voip
destination-pattern ....
session target ipv4:x.x.x.x
dtmf-relay h245-alphanumeric
codec g711ulaw
dial-peer voice 1 pots
trunkgroup 1stTrunkGroup
destination-pattern 91[2-9]..[2-9]......
direct-inward-dial
forward-digits 11
dial-peer voice 2 pots
destination-pattern 9[2-9]..[2-9]......
direct-inward-dial
forward-digits 10
dial-peer voice 3 pots
destination-pattern 9011T
prefix 011
dial-peer voice 4 pots
destination-pattern 9911
direct-inward-dial
forward-digits 3
dial-peer voice 5 pots
trunkgroup 2ndTrunkGroup
destination-pattern 61[2-9]..[2-9]......
direct-inward-dial
forward-digits 11
dial-peer voice 6 pots
destination-pattern 6[2-9]..[2-9]......
direct-inward-dial
forward-digits 10
dial-peer voice 7 pots
destination-pattern 6011T
prefix 011
dial-peer voice 8 pots
destination-pattern 6911
direct-inward-dial
forward-digits 3
