Transformation Pattern Fails
I have a Version 8.5 deplouyment with all the usual servers.    Of late I am seeing more mal-formed ANI hitting the system, generally the result of the caller using SIP trunks!   Anyway I need to fix that ANI so that I get a useful CID for some UCCX scripting we use.   I set up a new CALLING PARTY TRANSFORMATION PATTERN and put them in a partition and CSS that is searchable by my PRI's. I set the Calling Party Trasfromation CSS on the PRI to use the partition and pattern I setup.   The CID on the subject calling party however does not change (i.e. \+70022 ) and I just cant figure out where I am blowing it.   Is their a precedence or order I am missing?
Though I am very happy just to alter their incoming CID to a fully formed +1ANI I would prefer to also change the number they are calling (something you can do with translation patterns, but not with Transformation patters).
I use DNA to test and that is how I know it is failign.
Ayodeji Okanlawon
Is this a sip trunk? Died you uncheck use device pool CSS?
Sent from Cisco Technical Support Android App
Please rate all useful posts
This is not with sip trunks, but I did find the root cause.   In the PRI configuration, there is a section "Incoming calling party settings".   YOu can isther assign the CCS here for each of the number types or check the box to use the Device Pool CSS.   I did the configuraiton but did not have the box checked!  Duh...
