2 Part Question Regarding DNS on CUCM
Jacob Webb
I am installing a new cluster (the first on I am doing without professional services) and have 2 questions regarding DNS configuration.
1.     Do I need to configure DNS during the installation process?  Do I need to have DNS running at all?
2.     If I were to change DNS later, would this afect my license mac?
Also, can anyone tell me which settings make up the license mac?
Rob Huffman
Hi Jacob,
1. DNS is not a 100% must while installing/running CUCM but there is
debate if this is a "best practice" or not
from the 9.x SRND
Domain Name System (DNS)
DNS enables the mapping of host names and network services to IP  addresses within a network or networks. DNS server(s) deployed within a  network provide a database that maps network services to hostnames and,  in turn, hostnames to IP addresses. Devices on the network can query the  DNS server and receive IP addresses for other devices in the network,  thereby facilitating communication between network devices.
Complete reliance on a single network service such as DNS can introduce  an element of risk when a critical Unified Communications system is  deployed. If the DNS server becomes unavailable and a network device is  relying on that server to provide a hostname-to-IP-address mapping,  communication can and will fail. For this reason, in networks requiring  high availability, Cisco recommends that you do not rely on DNS name  resolution for any communications between Unified CM and the Unified  Communications endpoints.
For standard deployments, Cisco recommends that you configure  Unified CM(s), gateways, and endpoint devices to use IP addresses rather  than hostnames. For endpoint devices, Cisco does not recommend  configuration of DNS parameters such as DNS server addresses, hostnames,  and domain names. During the initial installation of the publisher node  in a Unified CM cluster, the publisher will be referenced in the server  table by the hostname you provided for the system. Before installation  and configuration of any subsequent subscribers or the definition of any  endpoints, you should change this server entry to the IP address of the  publisher rather than the hostname. Each subscriber added to the  cluster should be defined in this same server table via IP address and  not by hostname. Each subscriber should be added to this server table  one device at a time, and there should be no definitions for  non-existent subscribers at any time other than for the new subscriber  being installed.
During installation of the publisher and subscriber, Cisco recommend  that you do not select the option to enable DNS unless DNS is  specifically required for system management purposes. If DNS is enabled,  Cisco still highly recommend that you do not use DNS names in the  configuration of the IP Communications endpoints, gateways, and  Unified CM servers. Even if DNS is enabled on the servers in the  cluster, it is never used for any intra-cluster server-to-server  communications and is used only for communications to devices external  to the cluster itself.
Deploying Unified CM with DNS
There are some situations in which configuring and using DNS might be  unavoidable. For example, if Network Address Translation (NAT) is  required for communications between the IP phones and Unified CM in the  IP Communications network, DNS is required to ensure proper mapping of  NAT translated addresses to network host devices. Likewise, some IP  telephony disaster recovery network configurations rely on DNS to ensure  proper failover of the network during failure scenarios by mapping  hostnames to secondary backup site IP addresses.
If either of these two situations exists and DNS must be configured, you  must deploy DNS servers in a geographically redundant fashion so that a  single DNS server failure will not prevent network communications  between IP telephony devices. By providing DNS server redundancy in the  event of a single DNS server failure, you ensure that devices relying on  DNS to communicate on the network can still receive  hostname-to-IP-address mappings from a backup or secondary DNS server.
Unified CM can use DNS to:
Provide simplified system management
Resolve fully qualified domain names to IP addresses for trunk destinations
Resolve fully qualified domain names to IP addresses for SIP route patterns based on domain name
Resolve service (SRV) records to host names and then to IP addresses for SIP trunk destinations
When DNS is used, Cisco recommends defining each Unified CM cluster as a  member of a valid sub-domain within the larger organizational DNS  domain, defining the DNS domain on each Cisco MCS server, and defining  the primary and secondary DNS server addresses on each MCS server.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/9x/netstruc.html#wp1184840
And;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/9_1_1/CUCM_BK_I05CD008_00_installing-cucm-91_chapter_01.html#CUCM_TK_PB18EE42_00
2. see below
Customer Impact from New Licensing Procedures
Cisco Unified Communications Manager on the Cisco UCS C210 Rack-Mount   Server uses a different licensing model than Cisco Unified   Communications Manager on an MCS server. The MAC address of the NIC  card  is no longer used to associate the license to the server.
Instead,   the license gets associated to a license MAC, which is a 12 digit HEX   value created by hashing the following parameters that you configure on   the server:
Time zone
NTP server 1 (or "none")
NIC speed (or "auto")
Hostname
IP Address (or "dhcp")
IP Mask (or "dhcp")
Gateway Address (or "dhcp")
Primary DNS (or "dhcp")
SMTP server (or "none")
Certificate Information (Organization, Unit, Location, State, Country)
The ways to obtain the license MAC are as follows:
Before installation, use the Answer File Generator (http://www.cisco.com/web/cuc_afg/index.html). When you generate the answer file, you also get the license MAC.
Note If   you use this method, ensure that you enter the identical parameter   values in the Answer File Generator and the Cisco Unified  Communications  Manager installation program, or the license will be  invalid.
After installation, navigate to Show > System in Cisco Unified Communications Manager Administration.
After installation, use the CLI command show status.
Obtaining New Licenses
The   process to redeem a Product Activation Key (PAK) for licenses at   www.cisco.com/go/license is changed for a license MAC. When redeeming a   PAK for a license MAC at this URL, you get prompted to select the type   of license that you want to obtain:
A physical MAC address — this is used when Cisco Unified Communications Manager will be installed on an MCS server.
A   license MAC address — this is used when Cisco Unified Communications   Manager will be installed on Cisco Unified Communications Manager on  the  Cisco UCS C210 Rack-Mount Server.
After you make this selection, the generation and installation of the license file follows the same process.
Obtaining Rehosted Licenses When You Change License MAC Parameters
When   you change any of the parameters that create the license MAC, the   license that you obtained with it becomes invalid. You must request a   rehosting of the license to obtain a valid license. The old license   continues to work for a 30-day grace period.
To rehost your licenses, you must open a case with the licensing team. Contact the licensing team at licensing@cisco.com.
During   the grace period, you can change the settings back to the licensed   values to make your original license valid again. If you need more than   30 days of grace period, change your settings back to the licensed   values, then change them back to the new values that you want to use.   You will get another 30- day grace period.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/8_0_1/delta/vmware.html#wp1058262
Cheers!
Rob
"go easy...step lightly...stay free "
- The Clash
Rob Huffman
Hi Jacob,
from the 9.x SRND
And;
2. see below
Time zone
Hostname
IP Mask (or "dhcp")
Cheers!
Rob
- The Clash
Thank you for your detailed answer, I found this very helpful.
Hi Jacob,
You are most welcome my friend
Cheers!
Rob
- The Clash
