2 port E1 card always Amber
W S H FERNANDO
Level 4
Level 4
I have 2921 router which has 2 port E1 card , I noticed that e1 card's LED light is always Amber, What is the reason for this ?
Regds
6 Replies 6
paolo bevilacqua
Check "show controllers E1".
This is sh controllers e1
E1 0/0/0 is down.
  Applique type is Channelized E1 - balanced
  Transmitter is sending remote alarm.
  Receiver has loss of signal.
  alarm-trigger is not set
  Version info FPGA Rev: 08121917, FPGA Type: PRK4
  Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
  International Bit: 1, National Bits: 11111
  Data in current interval (738 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 738 Unavail Secs
  Total Data (last 24 hours)
     0 Line Code Violations, 0 Path Code Violations,
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 86400 Unavail Secs
E1 0/0/1 is down.
  Framing is CRC4, Line Code is HDB3, Clock Source is Line.
  Data in current interval (741 seconds elapsed):
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 741 Unavail Secs
VGW1#
Both your ports are in down state and hence you are seeing the amber light. Are these connected to PSTN circuits? If these are, then you have them in down state. Layer1 is down. You dont need to bother about config this is layer1 issue(cabling related). If its a PSTN connection, speak to your provider.
Terry
No these two ports are not connected to PSTN lines, So getting amber always is normal ?
usually other FXO ports are not amber always while they not connected. !!!
Regds
Yes its normal if you have no circuit plugged into it.
Shutdown controller not being used.
Note: if you are not willing to leave 5 stars rating for posts that are 100% correct and made with the will to help, please refrain from leave ratings.
